It is currently Sun Jul 20, 2025 11:08 am
PostPosted: Sat Feb 05, 2011 2:08 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Filippo, I don't think you'll find one for that cheap.
Mojotone has a tweed champ, chassis only, for $400+.
I've built 2 amps from scratch.
I got the free plans from Angela instruments.com.
Single ended amp project.
One amp has all the expensive stuff in it, $500, then I built the cab out of 1/2" birch ply.
The other amp used parts I had, and used cheap parts, probably $150?
I also built the super single ended amp, using the chassis, power and output trannies, and whatever
else I could use from an old Dukane PA I got off e-bay for $50.
I don't remember how much more I put into that one, but I do remember paying an amp guy $300
to finish it, because the voltage at the power tubes was 550volts :shock: , or something like that.
So, the Angela amps sound great, but are noisy at idle, which goes with the territory with single ended jobs.
Only way I can see it for $200 is to scrounge around for the big parts, used.
Some suggestions, imo, oil filled caps where you can find the right values, a choke, instead of a resistor,
definitely a rectifier tube, and good tubes. I like the Tung Sol re-issues myself.
Amp building is more of a money suck than git-building. duh
It is fun though!
Good luck!
PostPosted: Sat Feb 05, 2011 6:53 pm
First name: Erik
Last Name: Jarvi
State: IL
Here you go. Blackface champ for $207, and the vibro for $10 more. I've dealt with Triode in the past, but not recently, they were pretty good guys to deal with when I did.
http://www.triodeelectronics.com/champrebuild.html
PostPosted: Sun Feb 06, 2011 1:52 am
First name: alan
City: Santa Rosa
State: ca
That looks to me to be the best deal,
but you still need tubes and a chassis.
Ka-ching! $300.
PostPosted: Sun Feb 06, 2011 8:59 am
Congratulations to your 11 year old! That's fantastic! He did a great job!
PostPosted: Sun Feb 06, 2011 12:06 pm
First name: Erik
Last Name: Jarvi
State: IL
Ka-ching! $300.
The With Tubes option is only an extra $40, one could in a pinch build a chassis out of wood scraps from the shop. Just make sure your grounding is correct.
PostPosted: Sun Feb 06, 2011 3:59 pm
Tweed Champ kit from the same place.
http://www.triodeelectronics.com/5f1kit.html
PostPosted: Mon Feb 07, 2011 12:20 pm
First name: Jonny
Last Name: D
Heya Filippo,
Check out http://www.ax84.com
It's a forum for tube amp building guy's with great info.
The list a couple std starter schematics including complete layouts and mods. Everything is incredibly well documented and they've got a great pdf file that explains exactly how everything works + exactly how to build it start to finish. the forum can help with any hiccups.....etc.
Doberman amps sells kits for some of the amp designs on ax84.com
http://shop.dobermanamps.com/category-s/3.htm
They start at $259 including a blank aluminum chassis and tubes + eyelet board for their 5 watt P1 amp. Does not include wire
Or go $269 to add a 2nd 12AX7 tube for some screaming distortion....
Sadly, I dont belive you will find cheeper.... I've been lookin for a while and have been unsucessfull....
PostPosted: Wed Feb 16, 2011 12:32 pm
First name: David
Last Name: Lush
City: Louisville
State: Kentucky
Filippo,
If you find that your parts tally ends up around the $450.00 range check out Bugera amps. I picked up a new Bugera 1960 head (all tube) and cabinet last year out the door for around $700.00 after a little haggleing. The head was 450 of it. Sounds every bit as good as an old Marshall Plexi IMO. Just be forwarned at 150 watts it gets a little noisy. I was playing it in the basement one day with the house closed up and my girlfriend came in from outdoors yelling, claiming it was loud enough that I might as well be sitting on the porch. It was not even a quarter of the way up. laughing6-hehe Just some food for thought.
David
PostPosted: Tue Feb 22, 2011 9:33 pm
I don't have any experience with building amps personally, but if you haven't already, I would recommend checking out www.thegearpage.net. They've got a pretty knowledgeable group of electric guitar players, and even have a few very well respected amp builders who post on there.
Here I a link to the general amp sub forum:
http://www.thegearpage.net/board/forumdisplay.php?f=3
Here is a link to the amp technical info sub forum: http://www.thegearpage.net/board/forumdisplay.php?f=11
Mark Burton
Hook 'em Horns
PostPosted: Thu Feb 24, 2011 6:51 pm
City: Quakertown
State: Pa
The Mission Amps 5e3 kit is awesome. Great sounding little amp!
PostPosted: Tue Mar 01, 2011 10:47 pm
First name: alan
City: Santa Rosa
State: ca
Filippo, what did you end up doing?
Anything?
Users browsing this forum: Bing [Bot] and 2 guests
